Window rattle
Anyone noticed when the roof is off and the window isn't fully up or down it rattles???
Am i missing something on my car?
yep same here, but only on drivers side. sounds really bad when u should the door with the window down, its going in for a paint next week so will strip the door down and have a look
ditto
Same here. Let us know what you find eh!
theres a screw that come loose and dropped to the bottom of the door once replaced your problem will be solved.:D
Originally posted by james300
I remember reading this before and Mac had the answer.......
Yea its a small bolt that goess through the glass;) tighten that nut and you will be rattle free;)
Goes through the glass?? I'm not with you on that one Mac! ?
So you telling me you did not know there was a hole in the side windows?
Alex remove the door trim;)
