Well I still haven't got to the bottom of my smoking exhaust problem. The car doesn't smoke when cold. It only seems to smoke when left idling for a while when fully warmed up and then not always from one exhaust. Sometimes both exhausts smoke, sometimes its only one.
The car has done 78500 miles so its probably the turbos. The smoke is mainly white but there is a slight smell of burning oil as well. I'm not too upset as thew turbos are covered under a warrenty but nly up to value of £1000. Does anyone out there have any idea of the cost of reconditioning the turbos at a nissan dealership?
The only other cause for the smoke that I can think of is a problem with the cylinder head gasket or the the head itself as mine is one of the very early cars. I 'll check the engine number and see.
Can anyone think of any other reason for the exhaust smoke? As I say it onlyn happens after you take the car for a run and then let it idel for a while. Its probably worth mentioning that thaqt car has had the cats removed when a full s/s exhaust was fitted earlier this year. The extra presssure may well have contributed to turbo seal failure if indeed that is the problem.
hello again folks,
Cheers.
Martin.
