I took the Z out today for a drive to B&Q, drove home no problems at a normal speed 60-70 on 'A' Road.......
Pulled up at home, unloaded Z (few plants!) and switched her off, went inside and the next door neighbour knocked the door and told me my car was leaking!?!?
I went outside to see the Z had dumped some coolant on the road on the passenger side about 12 inches from the front and about 6 inches from wheel arch, looked more than there was but it looked a lot!! :rolleyes:
It stopped and then I waited for it to cool down and checked the radiator which seemed to be full enough, I started the Z back up and let it run for 5-7 minutes and watched the area under the Z and nothing leaked (I was on my back under the car!!)
I did check all the fluid levels the other day and topped up the rad and the coolant reseviour (mistake??) Have I done something wrong, i.e. too much coolant in the Z and it spat it out or have I a dodgy pipe somewhere?
Is there somewhere on the coolant system that allows for it to be released without any problem caused to the Z? (I'm crossing my fingers for this!)
I know it was hot today and I 'think' that too much coolant in the system and it expanding due to the heat of the day is my problem (see how I keep pointing that out! :D ) or is there a major problem I need to be worried about??
Any help is appreciated ASAP!!!
Cheers,
Matty.
