Skid under braking?
Hey,
A few times whilst braking hard in the dry to avoid stuff (corners, animals, stingers...:D) my front wheels have locked up pretty easily, most of the skiddy sound comes from the pass wheel :confused:
When does ABS kick in - I thought it would do whenever the wheel(s) lost grip?
The car's got sackfuls of grip round corners, but not so much when braking. Better than any other car I've driven, I'll grant it that, but it seems too easy to do.
Anyone else have this? The brakes are stock calipers etc, the pads are the zedworld ones, EBS? Discs look pretty standard, not groved or drilled.
Pete
Pete I think your ABS sensor could be shagged! they should not lock up.well only for a split second anyway.
Bugger - thought summit was wrong. Think i can live with it 'til I've got some dough though ;)
I'll have a look for prices.
Cheers mate :)
Pete
Pete,
Mine has also locked up in the dry front nearside only and my ABS did not kick in either , even left a nice black line up the road :D
ABS may not stop wheels locking up on loose surface, maybe gravel etc. If your inside wheel is on gravel could be that.
I just disconnected mine because I don't like it anyway.
You should hear the ABS kicking in. Even it is on a loose road surface, the ABS should try to stop the skid.
Any error in the ABS and the light should come on. Does the bulb work? Does the ABS light come on with the ignition?
Stuart
Hmm dunno - I've never noticed it :confused: . I'll check out the bulb and see.
Will have to do a "testing session" :D
Cheers folks :)
Pete
PS : John - I expect nothing else from you - you hardcore racer you ;) !
:D:D
