Hi all,
I changed my rear shocks and springs today but one side seams higher than the other?? I have the front shocks to do next but can anyone suggest what might cause this? A mate thought it might be the rubber mounting that the spring sits into............
Vijay
you got the wrong spring on one side?
check you have the cups on the shock the right way up.
Leave it a day or two to settle before you worry too much !
Changed my Lancia on Koni shocks and hardened springs many many years ago and it took a couple of days to settle down to the correct ride height - the gap under the arches make it look like a Fiat Panda for a while ! :D
Hello Chris,
Nope, I checked it on a flat surface (no camber).
Hello Devil,
The springs were the same and I'm sure the front's wouldn't fit on the rear shocks. The rubber cups are defininetly on the right way.
Cheers Konrad, I'll give it a couple of days and see.
Vijay
There's no way Vijay would have got those mixed up as he used my car for practice last week! :D
Vijay,
Did your shocks come off more easily than when we did mine?
Hello Jon,
nope, they were a pia cos I had no one to stand on the hub :( just got the fronts to do now........................
Vijay
Originally posted by vijay
Hello Jon,
Vijay
I thought your mum was going to do that! ;)
Regarding the fronts, if they're a 2 man job, let me know and I'll come over.
Jon
nah, she dissapeared..............................
Cheers Jon, I'll let you know.
Vijay
good advice. It`ll sink down to normal ride height.:)
