April 15, 200322 yr Is it possible for a car DIY guy to change the clutch on axle stands? She went into a garage this morning and was basically told they can't do it so im tempted to do it myself saving some money along the way. Looking at the faq on ttzd.com it doesnt look THAT bad, maybe a bit harder that a cambelt change i did a few months ago.
April 15, 200322 yr Yeah its easily possible - whether its easy or not is another matter entirely. I refitted my box all by myself with the car about a foot off the ground - prepare to invent some new swear words ;) CheerZ, Andy
April 15, 200322 yr There`s a strange thing due to work load etc have tried to get a clutch done now by two garages one had it for two days and another for one and both returned the car saying they could`nt do it?............ Ahem Jeff TT
April 15, 200322 yr WTF??? The gearbox is a bit of a sod to get off - the splines are very long and as it comes off the engine, if it aint straight, the splines will drag a lot. Gearbox bolts can be a pain but with a nice long extension (I use 4 x 10" wobble bars to give a bit of bend) you can get to them all from the back. You could try dropping the rear mount slightly and letting the engine tip back on its mounts to give you that bit more room above the box. Due to the same reason with the splines, getting the box back on can be a bit of a nightmare too. Make sure the input shaft is in the clutch, line up the box so it is straight relative to the engine, and push like **** - it does go trust me ;) If you are removing the flywheel to replace the rear main seal or to fit a lightened one, be VERY carefull with the flywheel bolts - they have VERY shallow heads and can be easily stripped - TAKE YOUR TIME!!! HTH CheerZ, Andy
April 15, 200322 yr Cheers for the advice guys, i'm gunna give it a go. Ive taken tomorrow off work and she can stay in the garage over Easter if need be. No doubt ill be posting a few threads over the next day as i get to each questionable part. :) Cheers very much
April 15, 200322 yr Got it on speed dial matey ;) Already hit a hurdle. Undoing the 6 14mm bolts, 3 connecting each exhaust to turbo, one side fine, the other side all of them shierd. Suggestions on how to get what's left out? :p
April 15, 200322 yr Oh shit :( Only way is to either replace the quarter pipe (turbo-downpipe) or to drill out the studs and replace with nuts and bolts. Is it series 1 or series 2? Might have pipe for a series 1 with studs perfect if you're interested. If you do replace the quarter pipe you will also need the gasket between it and the turbo. HTH CheerZ, Andy
April 15, 200322 yr HHMMMM!! Thats interesting. Well, unfortunately, the motor that Jeff has refered to above is mine. And both of the garages, as Jeff says above have refused to force the bolts incase they sheer. Andy, are these the bolts that that you are refering to?
April 15, 200322 yr It depends if they have got the gearbox off yet or not. If they have then its the flywheel bolts, if not, then, erm, they aint exactly trying hard. HTH CheerZ, Andy
April 16, 200322 yr Andy, thanks v.much 4 advice and the potential turbo pipe dealy. Don't get me wrong i'm not particully into bodge jobs,but would there really be any problem in replacing the studs with nuts and bolts? I cant really think of any difference. If i did nut & bolt it and there was a problem, like a leak or something, i could possibly beg you to do a deal with me for the pipe then? Many thanks
April 16, 200322 yr If I remeber rightly, Jeff said that the bolts that they were having problems removing were the manifold bolts. They were even soaked in some solution over night to make them easy to undo but they obviously shit it.
April 16, 200322 yr LoL, youve got to question how ive gone about this. Your Z has gone to 2 garages who are having difficulties with bolts. Me on the otherhand, "hmm this ones hard, i need a bigger wrench and more power". Admittedly in my eyes these bolts shouldnt be to hard to sort out after, i don't know which u mean so it's a different kettle of fish. Don't really think you should be touching the manifold bolts 4 a clutch?
April 16, 200322 yr Cos, these do sound like the downpipe bolts - how soft are they? lol When they shear, they don't take that much force to break! However, drilling them out is hard work due to the studs being hardened. Make sure you have a good sharp drill bit and a variable speed drill so you can keep the speed right down. Fitting nuts and bolts shouldn't cause any problems - the only bit you may find difficult is getting the bolts through the top of the quarter pipe, then getting a spanner onto them. Apart from this, it isn't really that much different to having a stud in there. Use plenty of coppaslip to make the bolts easy to remove next time. Also use brass nuts if you can ;) HTH CheerZ, Andy
