do my brakes need some wd40?
when i put my foot down and lift up on the brake pedal a screeching noise comes from the front brakes. braking seems to be ok.
any suggestions welcome, thanks in advance
martin
89 jap TT manual 2+0
racelogic TC, c/b pipes, scarab front and razo turbo timer.
martin@farrin.co.uk
www.farrin.co.uk
Check that you have the two shims between the brake pads and the piston and that there is a smear of Copaslip on all those faces.
That usually does the trick.
thanks andy, do halfords or such like stores sell copaslip?
it could just be that your pads are worn.
Nissan engineered a VERY high tech solution and fully computer controlled method to warn you when the pads are worn wink.gif
When the pads need to be replaced, a small metal strip on the pads is touching the discs everytime you brake and this causes the screeching..
-Eric
http://300zx-twinturbo.com
[This message has been edited by lymon (edited 02-07-2001).]
Hmmm, now that's odd, because my Z hasn't got that type of pad, but my mates import MR2 Turbo (hairdressers car!) has .... They're not shown in the service manual either.
cheers guys, will have to take a look.
in my first post i may have been a little misleading i suppose its more of a cranking noise than screeching and there is no noise during braking.
its probably time for a pad change anyway.
thanks
martin
[This message has been edited by martinfa (edited 03-07-2001).]
