Just Bought My first Z. Any tips?
Hey Guys I just bought a 96' NA 2+2 300ZX. The chassis has 136k on it but the original motor was seized and the car came with a "new low milage motor" to put in it. I am trying to do all the preventative maintenance I can to it before I install it. ie all of the oil seals, timing belt kit, coolant hoses, vacuum lines, and ignition. Is there anything else I should look for or replace before I start putting things together. Thanks all.
There are a number of water pipes that can be removed and the system simplified.
The fuel rail has a short connecting pipe which is much easier to do with the plenum off, same with the dett sensor.
Okay cool I will look into that.
