February 21, 200323 yr Hopefully some one can help with the above called a couple of tyre places and they either don't wanna help or they don't know ???? I am running 265/40 ZR17 on the rear and 235/45 ZR17 on the front ...... At the moment there on 28 front and 30 rear got 100 mile round trip tom so want to make sure there right
February 21, 200323 yr Hi Bagins - don't want to hijack your thread but would like to add the following: What is the correct pressure for the space-saver tyre in the boot? My J-spec one says something like 44kg/cm2 (if memory serves me). What is that in good old blighty petrol station english? As for the correct tyre pressure for your car - haven't a clue as I run standard UK size 16". Danny
February 21, 200323 yr 28 and 30!? Holy cow.. Standard is 34psi front, and 36psi rear - and the general rule of thumb is that you increase the pressure about 2psi per 5% drop in profile.. You've also gone up in width, of course, which also makes a difference, but.. Check your tyre wear - I bet the shoulders are worn more than the middle, if they've been on a while.. I'd up the pressure to about 35psi all round, and see how it feels, and how they wear.. HTH
