Engine question
Have an 89 300zx 2x2 non turbo and need to replace the crank. Any ideas on where to find one?
Hi,
Welcome to the club,
Where are you located ?
Do you have engine building experience; as thats not something the average owner would do themselves unless you have a builder in mind and just need the part.
Likely pick a crank up from ebay but unless you know the seller how do you know its a good healthy crank.
Maybe best finding another engine to use as spares.
Finding a good one also would be down to your location.
NA and TT engines have the same crank so that should widen your search. Might be worth giving Jimmer at Powerzed a call as he may have one or know someone with one from a different engine build that was unrequired etc. At least you’ll know that it’s a part within spec as well.
