WANTED - OEM dipped beam connectors with rubber covers
Does anyone have a pair of the OEM dipped headlight connector plugs, complete with the rubber covers please?
I removed mine when I fitted HIDS back in 2009 and can't find them anymore.... Plus I modified the rubber covers to fit the HID upgrade and look OEM, so they'd be no good if I reverted back!
I've just bought a pair of Osram LED H3 bulbs as I would like to compare them with the HIDs ๐Ÿ˜‰ย
Thanks!
Hi Richard, I cannot understand how Nissan put such poor low beam lights on the Z!
I fitted HIDs some years back then my garage failed it on them.
I got fed up with changing them back & forth!
might be worth getting a new sat as my ballasts are big so not easy to hide
Arthur
I know mate - I guess it was the tech available at the time.... ๐Ÿ˜ž
I'm happy with the HIDs and have never had any issues at MOT time - I hide the ballasts under the nose panel ๐Ÿ˜‰ย However, I saw the genuine Osram H3 LED bulbs for ยฃ35 and thought I'd give them a try, just to compare with the HIDs and report back here..... They look nice quality - way better the Chinese stuff on Ebay - which are fine in my DRLs, but probably not up to the job for head lights!
On 09/01/2025 at 22:00, A 2X OK said:
Are these legal to use in the UK?
Same status as aftermarket HIDs.... ๐Ÿ˜‰
But with the Zed having projector beams, it will come down to the tester spotting you have aftermarket bulbs installed.ย
I have just the tester . . .ย
  • JaiKai unpinned this topic
