Underbody and all that goes with it.
Hi Guys & Girls,
The Porsche is up and running very nicely, so onto the 300.
I am looking to refurb the front and rear subframes, the whole underside, brake lines, PS lines & Fuel lines. Big Job.
Started by removing the rear bumper, looks like it has never been off before, then draining the petrol (still in the process).
Took some underside pictures of the task in hand, it’s not bad mostly surface rust. I will be cutting all rust out and welding it my
self, if I can build a complex Porsche engine and it hasn’t exploded after 300 miles, anything is worth a try.
E7BB6F80-0403-41B3-B1F9-D15070B0B44C.jpeg.d6826d5277c603ab22e5da3c8cb62d39.jpeg4B2DCEAD-0062-46C5-B2BD-ADDB2A3F4F3A.jpeg.cd9af7ab51b8a6fff759bb4fa7511d08.jpeg
BE2B1788-A506-41C3-BF41-9020F9D20CC9.jpeg.7d59b6ae033a9917aa7d5e1ca83c25e9.jpeg5D03E7EA-761A-4564-BB39-CCF34A4CE1E2.jpeg.0d0a294c21a011d109f653f758205ab9.jpegF5F9133F-106C-485B-913C-3700EFCF0440.jpeg.83ab7f725cf72b55b277125fcf099201.jpeg
3E0871E1-CA8A-4089-9748-2599CA5DCFCC.jpeg.3005c8fc4120c8fe180a571ee22e9a45.jpegAFBD9AE8-143C-4AC9-BD56-B7E51759E470.jpeg.7e0f1ac9b9a73d4db7bf16b948f98f25.jpeg44B2BE3E-3B10-48DF-8D43-DBDF31A11EF6.jpeg.ac1efc906b45c15f1859b13f677a1014.jpeg7EF10535-28CE-4CE4-AA2F-DA8BA54FF5D7.jpeg.1a570a49704307fd3fc1bf80c4ce8bed.jpeg23B614FB-6FEB-437A-AF61-FEAE2F5DBEEA.jpeg.a1d99d20a3300224fc69137047ca3c26.jpegD382ED25-5839-455B-9CFC-20D8028B4B6A.jpeg.5f569fdd158c677f5205f4bf2220bb4c.jpeg4BE48671-F38E-46A6-99B3-994CE3ADF906.jpeg.d3ed6ab9bde9d98059de6edf6afe093e.jpegD55D7420-0E24-445F-A763-86EC90746575.jpeg.64c7f029c1de2107a5845a6a73cc02b6.jpeg
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
  • Replies 96
  • Views 9.4k
  • I have started on stripping out the subframe today, most nuts have been loosened but the half shaft bolts will need some heat persuasion tomorrow.
  • Today I removed the acid etch primer was an old can, and purchased some, Rust-Oleum Hard Hat Anti-Rust Corrosion Primer 218. The laser had it off in seconds. I have also found out a few passes with th
  • Collecting parts for the rebuild.   Nissan OEM Timing Belt - Nissan 300ZX Z32  Part #: 13028-45P86     ZSpec Design Outer B-
Exhaust off and petrol tank out, those breather pipe were hard to reach ended up balancing the tank on axel stands and a piece of wood.
3B9BFA3B-8D07-4425-8809-53F72C6E488D.thumb.jpeg.e56db931ffc3930a8cbc0ee23123c2fe.jpeg6D924047-CA67-47F6-8848-B40C0372F25E.thumb.jpeg.20a8d7b02c4d74fbeb9f819de2e8c0c8.jpeg544A85E6-0724-47FE-8C18-B25A7C946E81.thumb.jpeg.5ffdacb52ccc550be8406f6e339d8a7c.jpeg0AEBAEF3-0986-4255-B104-35C84B06A4D0.thumb.jpeg.56c41744c0d288a86326b4a8704f1a68.jpeg
2004 BMW Z4 30i
Following this keenly as it's the project I'll be tackling once my house extension is completed next year.
Managed to remove the Hicas & propshaft, I will be putting a one piece prop back in. I have axel stands under the car now was very hard to do on the ramps, now I can remove the rear subframe. Had to use plenty of WD on the bolts, undo and tighten a few times. Does help to have a large breaker bar and a impact gun.
Wont be back to car for a week and a half, so that’s it till then.
1728CA32-9755-4532-B9E5-0619102B39F0.thumb.jpeg.34801df9c5c466381c37409e4ae17302.jpeg9EDBEA6D-7FA4-4870-9CB7-D543520CC34F.thumb.jpeg.061512ae34e906c596372d345e103abe.jpeg7A53EAFA-2A9D-4AE3-BE47-87C8AE62865F.thumb.jpeg.a584667649dcf11a4e46546fd83f3e64.jpeg721151EE-174A-4318-97ED-43D1C8821E58.thumb.jpeg.e9b47ee99f70a885dcc7d6c14a58290a.jpeg0FEEEACA-71DB-4458-8914-C245F10DF7C6.thumb.jpeg.658a736dc6fa014ae82d9c97ac54b1be.jpeg
2004 BMW Z4 30i
Flashbacks of dropping my rear subframe balancing it on a trolley jack ?
What's the plan for the underside? Strip and paint? I'm probably going to use the same Jotrun paint I used on the subframe and arms after attacking it all with a knotted wheel on a grinder.
I am lucky in having a cousin in the blasting & powder coating business, he will do all the metal bits. I am going to strip as much as poss underneath treat and paint, I will have to experiment different methods.
2004 BMW Z4 30i
  • 3 weeks later...
500AC225-2FE6-4BE2-A56A-C445C9D98015.jpeg.e64582e5665e8ff46efbe37e3a6c45b0.jpeg21131AFB-2CBE-406A-A42C-DE9BFD1B01FE.jpeg.46141d84e9c47d16bd49b7e1afa7d12e.jpeg1C53D0B6-FF76-425F-9E48-BC55F6D749CB.jpeg.4750729770d2183700db16b9e4e1c223.jpeg
23746BD3-31B5-4310-82D3-32965E72E3F0.jpeg.7982c499f813a10152ce6cc7b220fe8e.jpeg690217F1-3210-4E99-9F6E-35ACB78C7CFE.jpeg.eadbce451e2bb5aa952247bf11128fad.jpeg05D72E1C-5EF3-4E49-AC5D-7A9D8C7E0781.jpeg.ee85ee5d214ae65a024a2a4190e35cfb.jpeg
Edited by Bones28
2004 BMW Z4 30i
All stripped down apart from the bushes, will try and get the press out tomorrow.
922A8098-D1C2-406F-9DC5-758EFADC6E6D.jpeg.5ee6b3bf1828449bb11e867303dd3979.jpeg27FDCCE1-F7B7-4E1A-B81C-6693BD8D3C77.jpeg.cf477101b366dad83ccd4d20231692b6.jpeg7D5C5004-EFAD-49C0-A8BA-E68CD2577434.jpeg.6f8e06149177d0995e614ea6b0d10702.jpegCF0049BA-A399-44C6-986F-CEFB0B81B031.jpeg.b878cd9a8f9d8d09cc3a6bbced5da360.jpegCF684F8E-70B4-4CAE-A5BB-5B868B29574F.jpeg.38284c1645b884564ceb784e38fba83d.jpeg
2004 BMW Z4 30i
I’d avoid these, it’ll ruin the ride and your back. You use yours on the road so I’d put in poly bushes as a good compromise between stock and firm or Whiteline bushes maybe, just not solid ones.
Mine originally had stock worn bushes with subframe spacers which felt great, followed by Strongflex poly bushes which feel equally great and firm enough. It launches beautifully.
You using it as a track / Fast Road car? What about the rest of the suspension bushes?
I put Nismo in all mine but left the OEM subframe bushes in as they weren't split or leaking. Lee (Bird) put ES everywhere in his and he now hates the ride.
Following Alex’s post, for background, I should note that I put in Nismo everywhere else except the steering rack and diff. Also got BC coilovers.
I will have a look ? and see where to get bushes and spacers. The car will only be used on the road. I have ES everywhere else and MeisterR ZetaCRD Coilovers.
The rear was a bit harsh over the crap London roads and speed humps.
2004 BMW Z4 30i
I've the ZetaCRD and have them on the softest damper setting and even with that it's on the limit of comfort for me. I'm likely to change to something with softer springs in the future.
Prior to putting the Nismo bushes in the car was all OEM but had subframe collars on the rear. The ride was awful on UK roads. Actual solid bushes would be harsh imo.
Me and Lee did a little research and Hardrace do a set of rubber subframe bushes they claim fit the 300zx. I don't know anyone who has them though.
Edited by Lexx
Thanks for the input on this, I will get everything blasted and zinc primed then powder coated, whilst they are away will do some research
Wonder if just changing the springs on the Zeta would be ok.
2004 BMW Z4 30i
Bit more done today, some parts ready for shotblasting and powder coating.
Rust isn’t to bad have seen much worse, I will get on grinding next week.
076C3BDB-253D-4D65-9EB2-90DC3FE0C3FF.thumb.jpeg.4028d800e9edd4c637da334fcd06bb90.jpeg85FF407E-8B02-4424-8ED1-588F99DE75BA.thumb.jpeg.74d1cb61b4b1aa5fb456d19ec33f1234.jpeg
F6625619-97FA-405F-A4D1-DB5A01A73B06.thumb.jpeg.ac2e92757bc0f3929efb9e6e02784d4a.jpeg8030953F-7B1D-4B50-B704-D7A967605A2F.thumb.jpeg.106ed46565de9190e9fb019b9cc7a0b3.jpeg7895F876-5505-4B1D-98D8-ECFF891C8BC1.thumb.jpeg.83d2cd3fbb1eef30bb309dbbbea6acac.jpeg
Edited by Bones28
2004 BMW Z4 30i
  • 2 months later...
Finally I have found some time to start stripping the underseal off.
B92DAB27-9CB2-4C68-8080-4D05B25BFF2C.thumb.jpeg.af106cfc5565d427a4f1fcc4a52b15ed.jpegAB79848B-CB38-4C91-8F39-0C22500D6CA9.thumb.jpeg.193772b7e7f69999f40bbb47609715e3.jpegE810B6E2-848B-4AF5-9E47-579E140811D9.thumb.jpeg.b63407a2bde27873b2b774366c6d575b.jpeg2274E66C-A472-4330-B3CA-19F801DF649C.thumb.jpeg.ac690122ac4874c33c645dcc01a273c3.jpeg997ECAC9-5B4F-4594-AB30-A212B7567748.thumb.jpeg.74f3fef540e084fa63a23b0bad390395.jpeg
2004 BMW Z4 30i
6 hours ago, TheRealNips said:
That must be a horrible job, taking that stuff off ?
It is messy, I’m using a variety of tools, a fen, angle grinder with flap disk and a poly abrasive wheel.
2004 BMW Z4 30i
1 hour ago, Peage said:
Can it be chemically stripped at all?
It can be but makes a horrid mess and the fumes are dangerous.
2004 BMW Z4 30i
  • 1 month later...
Hi I did a bit more today, you would have never known these spot welds were rusting under the pristine undercoating.
2004 BMW Z4 30i
Can be quite worrying when you see things like that. Turns out on one of my doors under where the pin striping usually goes, it was rusting. Had no sign at all from above the paint though.
  • 2 months later...
Hi I haven’t done a lot recently, been looking after my mum who has Alzheimer’s, so car is at the back of the queue.
I did manage to do a little bit more, purchased some protective equipment.
The mess it makes is so bad.
What I really want is a Rust removing Laser.
2004 BMW Z4 30i
