- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi all, I have just installed a haltech platinum plug play ECU and seems to be having issues with it turning on after checking relays and fuses I can see that when the car is in the on position pin 3 on the eccs relay is showing 5v so I replaced the relay with a new one and still same issue, however when I remove the relay and jump the relay connection therefore giving it direct 12v at pin 3 the ecu turns on and it all works like normal.
Therefore if it's not the relay what could be causing the 5v at pin 3 instead of 12v
I am running no MAF if that makes any difference and the car is a 1991
Any help will be much appreciated
