I have ordered some new 52mm gauges to put in my empty din, oil pressure, boost and water temperature.
How can I put the new Water Temp sensor and the stock sensor on at the same time? I have been told there are no T-Peices for it.
Can I use the same one from an oil pressure T-Peice?
Stuart
Stuart
You need a small section of pipe to go in the top hose. You basically chope the top hose, insert this pipe and it has a boss welded into it for the new sender - does this make sense???
CheerZ,
Andy
Stu, the boss for the water sender needs to be in either the top rad pipe or the pipe going to top of block, the first one being the easiest, have done a stainless top rad pipe with the boss on for a few guys before, when you get your gauges it has a boss with it, if you want us to do a pipe for you, just send the boss to us.
cheers
smithy :cool:
Errga what?
Boss? What?
Do you mean like that brass nut with a tread on it? If you know what I mean. ;)
How much would that cost though?
What thread is the stock sender unit? Cos it dont fit in there either. The sender unit is too thin and the adapter (Boss think I think you are talking about) is to big.
I got my new Boost gauge in. It looks cool :D
Stuart
Stu, by sending your brass boss (which should match your sender unit) to us that comes with the gauge, we can match the thread in it and use a small stainless boss instead which is welded on the side of the top rad pipe which we make in stainless, the whole lot including silicone and hose bands is 45 squids.
cheers
smithy :cool:
Thanks Smithy,
But I think I will have to save a little money. I spent £120 on dials, tax is due and I have spent loads on petrol latley.
PS. You still got my dials? I was gonna try make my own. I found a company in the US who will assit me in attampting to make some.
Stuart
