Is it worth it
So the search has come up with a k plate na it was originally silver but it has been taken back to bare metal , and the lower sill have been welded, and has been respirated cobalt metallic green, itโ€™s done 68k it had a cam belt and water pump at 60k, the car is in Manchester, at a place called Salford body repairs, the guy is asking ยฃ6500, does this seam resinoble or should I chance my arm and have a haggleย
19 hours ago, Lexx said:
Has he fixed the gearbox issue?ย
Good question he never mentioned thatย
We will see Iโ€™ve just messaged him?
He said itโ€™s a bit better, and is going to work on it todayย
I'd walk away. If he didn't mention it to start with what else hasn't been mentioned.ย
As I said before, I'd genuinely consider importing one from Japan.ย
Zed #2: 1998 Midnight Purple 2+2 NA. (owned 2020 - now)ย
Can you name anyone who can help pleaseย
5 hours ago, Gaz 300 said:
Sounds dodgy mate.
Yup - sounds like the auto box is on its way out - that's how the symptoms started in my old red Zed.... The box will need a full rebuild (circa ยฃ1200 at an auto-box specialist) - or budget for a manual conversion. Which, being an NA, I'd get done - NA autos are dreadfully slow!
Or prehaps just doesnt know the function of the A/T switch ?
I got through 4 autos before a manual conversion.
Getting a manual will cost around a 1K then,ย new fly wheel/clutch/master & slave cylinders ect.
I never used the A/T switch BTW but mines a TT
ยฃ6,500 with a gearbox issue !! seller is taking the pee!
