Goosehonk comes about when an aftermarket filter is fitted. This is because the new filter is far less restrictive and allows the air blown into the intake tract by the recircs, to blow back past the MAS and out of the filter. This doesn't happen with the stock airbox as it is far more restrictive. Replacing the recircs will not cure the problem - maybe fitting faulty seized ones will though ;)
So, infact, the recircs are not even doing their job - the whole idea is to retain the air in the system once it has passed the MAS (its been measured into the engine so the ecu will fuel for it). So, what's your excuse for not buying BOVs now eh??? :D:D:D
Ok, this may have been suggested before but.....
Any thoughts?
CheerZ,
Andy
