Posted
My gear selector is not as direct as I would like.
I believe this could be worn bushes.
So I was thinking of getting a short shifter & any advice would be welcome.
Arthur
My advice is DO NOT fit one.A alarming number of cars i work on with one fitted have gearbox issues.It will turn your box into a David Brown 6 speed that was fitted into a 1978 Scammell Routemaster.Treat your original shifter to a rebuilt pivot along with new bushes.And if play is still present it is possible the Striker Rod Universal Joints are worn.The striker rod is available new still.
Hi Jimmer
thank you for the swift reply.
Is it a job that can be done inside the car?
Many thanks
arthur
What Jimmer said. I have a short shifter in mine and hate it with a passion.
Once my suspension and chassis work is done and I turn to the inside of the car my will be getting deep sixed off the back of the boat and replaced with OEM. Hateful things.
For the 34139P-30P00 bushings http://www.ttzd.com/tech/bushingstech.html
As you had a manual conversion, on reassembly make sure that the upper and lower rubber dust boots (pictures 6 and 7 in the guide) are
present and correctly fitted to stop road and transmission noise getting into the cabin.
I see that Z1 do a kit for the pivot rebuild which is nice.
https://www.z1motorsports.com/z1-products/z1-motorsports/z1-300zx-z32-speed-shifter-rebuild-kit-p-3519.html
Edited by AndrewG
9 hours ago, arthur said:
Hi Jimmer
Many thanks
arthur
The stick will need removing which is possible from inside,Just !! The striker rod replacement requires the box removing.
I had a look see at mine the last time I had the console out a few months back. Jow the hell my elephant paws are supposed to get in there I don't know! Kids will be doing child labour for me I think.
On a side note Jimmer - what's your preferred method of contact to discuss  booking in a 120km service and a few other bits?
I've driven a huge number of Z32 over the years, some of them with a 'short throw shifter' fitted and they're absolutely HATEFUL.
The stock throw is fairly short, the only thing that needs doing is the bushes replacing. You can go for the bronze ones, but honestly, the nicest feeling are a new set of stock nylon bushes.
Short Throw Shifters are about as over rated as Christmas and football.
Thank you Si & all.
I will stick with my stock one & go with a set or nylon bushes.
have a good coming year !
Arthur
When you are ready give me a call or ping me on jimvg30dett@gmail.com
had a short shifter in mine, bloody thing was horrid, I removed it a couple of years ago, unfortunately its left my car with a bit of a clunk/grind between 1st & 2nd and 2nd & 3rd luckily I have a spare box which I'll get jimmer to chuck in when the clutch needs replacing.
Hi there all,
Why have you tagged my thread?
Can the committee respond?
art
Hi there all,
art
What tag you referring too? I've just checked the moderating logs there's nothing showing as out of the ordinary.
Thank you for replying
apologies my misunderstanding
must be an age thing!
gearbox bushes are on the way?
Art
