Fuel tank retaining straps
Hi can the fuel tank retaining straps  be  completely removed with  the sub frame  in place  as why I've got the tank off I was going to  clean them up an  paint them thanks
I believe so.
I had the fuel tank and straps replaced on both my Zeds - one by JeffTT and the other by my local garage. And neither ever removed the sub-frame to do it?
4 minutes ago, RichardS said:
I believe so.
Thanks  I get  right under the  car an have a good look  when  I  took the heat tray off it looked close to the subframe
The subframe can 100% stay in for a fuel tank swap unless it is a swb model.I know Stephen your car is a lwb model.
Thanks yes got the tank out  I undone the  straps nearest to the  bumper  I just wasn't  sure about if the straps could be completely removed. tank strip and primer  just top coat to do
Edited by stephenk
I have this job coming up soon, was it difficult? Im guessing the fuel pump/sender unit needs unplugging, straps unbolting and it just falls straight on top of you?
 It's  not  difficult  it  just  takes  a bit of time  you got   the  2 fuel lines to remove   the tank an fuel neck have  1 pipe each   1 electrical  connector  the fuel neck as a cover  that  as to be removed  I undone  the 2 retaining straps  bolts  closest to the  bumper  my bumper  was removed  I'm not 100% sure if the bumper  as to be removed  to get to the bolts
