Washer Reservoirs
Spent ages today trying to work out why my washer jets were not working, started by filling the engine bay reservoir, still nothing just the motor buzzing.....
Stripped out the N/S/F wheel arch liner, water bottle seemed ok, pipe at bottom nice and tight....
Then found another reservoir in the boot area... filled it up... still nothing but motor buzzing sound....
Then put air line on front washers, air pressure forced out apparent blockages.... front washer jets now working:classic_wink:
Also can someone confirm is the front reservoir for the rear wiper, and the rear reservoir is for the front wipers??
Edited by E8VEN
10 minutes ago, AndrewG said:
Washer reservoir in N/S/F is radiator expansion/overflow tank.
Thanks for clearing that up, so I was completely wrong!! So the washer reservoir is just the one in the boot area:)
No the front O\S is washer bottle. The N\S is radiator overflow bottle.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
Sorry forgot to mention my ZX is SWB so only has the one reservoir up front, which I now realise is the radiator overflow bottle...
If the bottle is empty this should be indicated by an amber dash light, picture of a windscreen with jets of water.
The washer bottle configuration changes with model specification, so the swb and lwb are different and the U.K/Euro version are different again.
My 2+2 jdm car the bottle is located behind the drivers side intercooler and has two pumps and a level switch.
Uk cars the location is the same but there are 3 pumps and a level switch, the bottle is also a slightly different size.
2+0 cars have a rear a rear mounted washer bottle. I don’t believe there is one located in the front.
If you have a front bottle it will be in the drivers side, if you lift the bonnet there will be a fill cap in the corner below the power steering pot. This will be a clear colour with the standard washer symbol on it.
In my late 94, series 4 slicktop, I do not have the reservoir in the l/h rear, just the one r/h front with sure it's two pumps, wonder if my 95 is the same, I expect so.
I remember seeing earlier SWB's and spotting the rear filler cap and pointed out that I don't have on mine to the unaware owners.
Well I never would have guessed they changed the location of the washer bottle. Totally unnecessary.
2004 BMW Z4 30i
Maybe, or was it part of a number of small changes to keep the weight distribution sensible.
The last place I thought the reservoir would be is in the boot area, obvious area to look was the engine bay, anyway really appreciate the input from all members??
