Hi all, my car was originally a series 1 NA LWB and was converted to a TT years ago.
Since then I have also fitted a TT auto box and had to swap the TT cog on the speed sensor to an NA one as the rear diff is an NA one.
The speed sensor was rotated 180 deg and a clamp made to hold it in place.
Now the speedo has stopped working. I have resoldered all the connections on the speedo in the cluster, cleaned cluster connections and for one trip it worked.....
Next day nothing again....
I can't get to the speed sensor connector to check for corrosion as it appears to be on top of the auto box and unreachable....
The car is on its wheels and sitting on blocks.... so can't turn the wheels and see if the pulses are getting to the dash plugs!!
I bought a cluster and have realised it is a later one.... 24810-32P00.... The sockets are all horizontal..... not sure what series this is from?
Can it be modified to fit or is it a sell it and find a series 1 NA cluster??
Russ
That’ll be from a series 2+ Russ. Many of the pin outs of the connectors are subtly different too, I would sell it and purchase the correct cluster so you don’t give yourself a headache introducing more gremlins!
I was hoping to have bought a spare to use to test mine and for future spare.....:crying:.....
Typical, can't even swap the speedo section over.... lol
