What my Conzult meassaments says.
Hei. Maybe somebody can tell me if some Conzult meassaments are not ok.
CMPS/rpm: 850 RPM
MAS AIR/FL. 1.16 V
AIR FLOW. 8 CFM
THRTL POS. 0.44 V
IACV-AAC/V. 20%
COLLANT TEMP. 80
FUEL TEMP. 23
IGN TIMING. 15 BTDC
BATTERY. 13.74
VHCL SPEED. 0 KM/H
O2 SEN-L. 0.04 TO 0.46 V
O2 SEN-R. 0.04
A/F ALPHA. 94%
M/R F/C MNT-L. LEAN
M/R F/C MNT-L. RICH
INJ PULSE. 1,53 M/S
INJ DUTY. 1.08%
I'am struggeling abort the O2 SEN-L. Its variating very. quick between 0.04 and 0.46.
Hopefully get some help.
Have you got the ConZult user manual? See page 39 for O2 sensors.
ConZult user manual.pdf
I've found that O2 sensor readings can stick (not fluctuate), so it is worth running the engine for a
while (~2k revs) to see if it will behave normally before deciding the sensor is faulty.
Edited by AndrewG
