Guys i am looking to replace all the bulbs on the outside of the car with led bulbs(break lights,reversing,indicators,etc)with leds has anyone done this and what kind of leds do i need,Any info would be great.Thanks all
I had Phutumsch fit Cree led bulbs to my fog and reverse light positions , they work really well, indicators if memory serves will need a resistor fitting to get them to flash properly. I'm sure some of our lighting gurus will post advice soon.
I have replaced my reverse light bulbs with LEDs - they are certainly a lot better....
….As for brake lights (and rear lights) and indicators, I believe Ian has a point - the lower current draw from the LEDs will give you a bulb-out warning in the rears/brakes; and the indicators will flash erratically, as if you had a blown bulb. You can add a load resistor to mimic the draw from a standard bulb - but personally, I'd not bother and stick with normal indicators and rears....:wink:
I wouldn't bother personally as per Richard's comments plus the way LEDs defuse will give you light spots on things like indicators and rear lights.
BIG difference. Yours is an LED array, not a universal LED bulb replacement. :lol:
I tried replacement straight swap led bulbs they just didn't work so I put em back to std.
