Bleeding the abs module during a brake bleed
hey guys just wanted to ask has anyone every bleed the abs module after bleeding all for calipers during a standard brake bleed as the fsm states in the braking section?
just wanting opinions if you should do it or not really.
Why would you not bleed from there? I may have skipped it once or twice for a routine fluid flush, but I usually bleed from there and especially if I have broken into the system anywhere.
Excellent just what I wanted to hear, thank you joely p. Last time I bleed my brakes back in 2011 (I know a long time ago) I never touched the abs module but now I am OCD when it comes to servicing my Z and I wasnt sure if the ABS module would get bleed as you bleed the calipers anyways. I am going to be swapping my front brake calipers so the system needs to be bleed anyways and I felt I need to get the old brake fluid out of the ABS module asap.
I'm planning on using a power bleeder tool to pressurise the system from the brake master and then push the brake fluid out from the calipers and abs module.
