Never done it before, and am reluctant to do so in case it becomes a horrible fiddly job that you get stuck half way through.
I have seen a few vids on youtube and there seems so many
bolts, clips and lines to remove, so should I leave this job to
an experienced hand?
Main reason for removal?
1) Have 1 bad injector which I see as a real ballache to remove as the 2 screws that hold it in place have probably been there for 20+ years that will probably end up with stripped heads and without the plenum removed will be impossible to get to!
So who's been in the same boat when facing the above? and what would you recommend?
