Hazard Light Switch
Hi
Has anyone got or know where i can get a working HAZARD Light Switch, My car is sat in Garage needing this for MOT ||| so i need it URGENT, i am in Fareham HAMPSHIRE so would need to be posted ASAP. or does anyone have any ideas if any other switch will fit in so i can get my Car back.
Contact Below.
SIMONM5@SKY.COM
Text : 07980 889942
If you don't have success on here there is one up on eBay:
https://www.ebay.co.uk/itm/Nissan-300ZX-Z32-1990-1999-Hazard-warning-switch-button/123293352760?hash=item1cb4db4338:g:xNAAAOSwPWRZPw75
Have you checked that the harness plug for the switch is connected properly?
Lights are working, basically the switch is broken, the Push Knob is not Holding on (lugs Missing) and the switch is a bit tempremental.
If you run out of time finding one you can borrow mine to get it through the MOT, I’m in Langston, Havant. Just swing by and Collect, bring your broken one as I MIGHT be able to fix it.
That all sounds like it's fouling, check the mountings would be my advice.
@.007
Great offer! truly appreciated, I have managed to order the one from the link in earlier post hopefully it will get here shortly (before 10 days up then another full MOT) if i get stuck i may have to make the Trip to Langston ! My mechanic is pretty old school and he is going to see if there is anything he can do to fix it, so fingers crossed.
Again thanks for the offer will Be in touch if needed.
