Gearbox dimensions
Can anyone tell me the length, width and height for the manual gearbox? Trying to work out if I can fit one in my car!
Tried searching for this but not much coming up. Thanks!
What car do you intend to put it into? The weight would concern me more.
It's for fixing into a Z. I meant for transporting only. Sorry for the confusion!
Think Stephen meant what car are you going to transport it in ! an estate car, a hatchback, Ford Focus , Mondeo etc.
One thing I would warn you of, the oil in manual gearbox`s smells like sh*t and spill it into your boot and you will smell it every time you use your car.
Plastic line the boot area and two or three old sheets too, stop up the end of the output shaft, keep it higher to prevent oil loss ( assuming it has oil in ) oh and the weight is a consideration if lifting over a high boot lip on your own.
Jeff
