Missfire developed
- Replies 26
- Views 2.1k
- Created
- Last Reply
Alic 9 posts
Stephen 7 posts
bird 4 posts
redwine300 4 posts
Just in case anyone has any suggestions to help me before I order some injectors.
So the morning of the AGM the car started up missing on the front two cylinders which were previously running fine.
First cleaned the injector plugs, no joy. Ive swapped coils and the problem persisted, checked spark and the spark is strong, pulled the plugs and they are dry and white leading me to believe it has indeed got no fuel.
So I checked the resistance of the injectors and they are within spec at 12-13.8 ohms. Voltage also checks out at 12.8V (early style injectors btw).
So although they are within spec the cylinder still has no fuel in it so may just put some new injectors in (hopefully before Simply Jap).
Any other suggestions?
