Relay idetification
Hi all,
behind the drivers footwell fuse board are a number of relays as you know. Can I ask which one controls the wipers, clock, left pod and cig lighter.
Thank you in advance,
Steve
Accessory relay. It’s the blue one that’s nearest the driver when the fuse box is in place.
I have a Nissan 300zx project I’m working on and I have lots of questions as well as answers. Hope to learn and pass on knowledge as well.
I’m trying to figure out where to hook the power wire (in the fuse panel) that goes from my relay that’s wired to door poppers I’m trying to install. Should I even be hooking it into the fuse panel or somewhere else?
Welcome to the club Paul is your Z a z31 or z32 300zx ?
Does anyone know what each relay controls please...specifically the blue one next to the one I am replacing (horizontal too). Thank you
Finally, am I right in saying that the parts number for the defogger brown relay should be 25230 C9963. Not with the car and would like to order before getting back home if possible, hence the question.
Thank you again
Thanks man I appreciate that. I have a 90 z32. Been trying to figure out where to hook the power wire into that operated the relay. Do I wire it to a separate fuse that shortstops the fuse panel and then connects directly into the fuse box or do I connect it directly to the fuse box. My other question is where on my fuse panel should I connect it to. I don’t wanna blow anything. But I only see 10, 15, 75 on the fuses and I’m like.....what does that mean.
  • 4 years later...
On 22/05/2018 at 13:56, AndrewG said:
Power supply routing which indentifies relays and the circuits they control:
el-10-11-1.pdfUnavailable
and diagram of fuse block/junction box identifying relays:
Hi, came across this.  Not sure if anyone will reply.  I’ve a buzzing blown -bulb check relay as in above diagram.  What does it do,  and are there replacements etc available… cheers
