Re Circ valves
Hi all, I recently had my 300ZX smoke tested, it appears that the Recirc valves themselves are leaking, (not the pipes which they connect to) so, my question is ,can these be reconditioned, if so how ? , and where do I get the necessary parts ?, I do not get the noise described as goose honk, Or are there any companies that will re con the valves and properly test them ?
Thoughts
Sayers
Unfortunately the OEM recirculation valves are not serviceable and are NLA from Nissan. Specialty-Z in the US
sells an aftermarket replacement:
https://specialtyz.com/shop/gfb-go-fast-bits-recirculation-valves.html
The "goose honk" is described here with the fix for stock recircs:
http://bde-performance.com/goose.htm
and you can see why the OEM's aren't serviceable from the photos.
Edited by AndrewG
GHK link description
I wonder where to set them to give the best performance? I do see they are adjustable
T9135 information here:
http://www.gfb.com.au/products/blow-off-and-diverter-valves/mach-2/mach-2-tms-recirculating-diverter-valve-35mm-inlet-30mm-outlet-suits-my97-98-wrx-sti-detail
and T9135 installation instructions:
http://www.gfb.com.au/phocadownload/Mach_2/t9135%20instructions.pdf
Edited by AndrewG
Correction to product links
bloody hell, these things are 150 quid EACH,
Anybody help with Alternatives ? looked at Ebay and there seem to be a lot of Re circulation Valves with 25 mm ports, Or should I simply fit dump valves, ??
I fitted a pair of Bailey DV26 I believe, atmospheric dump valves. Not a perfect solution and it makes simon crawl out from under his bridge, but did it.
Anybody know if Re circ valves from any other Vehicle could be fitted ???
Anyone know what size the inlet an outlets need to be , im not sure 25mm is correct?
I’ve got a pair in the shed mate. If I get time tomorrow il measure them but iirc the inlet and outlet are different diameters.
My apologies, for the GFB installation in a Z32 the correct part is T9135 with 35mm inlet and 30mm outlet (in my posts above SZ link
is for the correct part whilst the product and installation instructions I posted were for the T9125).
"T9135 is suitable for custom installations, and is also a direct factory replacement for:
· Nissan 300ZX Z32 (2 valves required)"
Edited by AndrewG
