My daughter calls it Toothless the Dragon: My ‘95 TT Z
As with most projects and rebuilds, they all start in the same place, mine was no different. However, this isn’t truely the start of my forever ongoing Z project. I’ve owned this car (my second Z) since 2008 when I purchased it from a former member. For the first 5 or 6 years I did the usual mods with suspension parts and basic bolt ons. For reasons unknown, whilst running stock boost, piston 5 cracked a ring land during a track day at Castle Coombe. A forged build and a remap later all was well until a sunny October’s day 2013 at Bruntingthorpe killed that engine with what at the time was a suspected head gasket failure at 181mph..... And this is where I shall start my journal.
The Z was stored off the road from Oct 2013 until March 2015. I’d had a major knee operation at the beginning of 2015 which meant I was going to be off work for 6 months. I’d saved up enough to start thinking about a parts list to rebuild her and frankly, after a couple of months of staring at the same 4 walls, I was going stir crazy! I employed the help of a good friend and decided to pull the engine and see what was what.... just a head gasket my arse!
March 2015
Problem 1: It turns out stainless steel, exhaust wraps and condensation don’t mix well
Before I’d even got the engine out, a new set of downpipes was added to this list. These AMS items were only 2 years old, so I was far from impressed! I contacted the retailer and after a bit of tooing and froing I secured myself a set of replacements for free... how long they will last, only time will tell!
  • Replies 674
  • Views 103.6k
  • Hey all.   well I’m happy to say my engine saga is now pretty much behind me and I’m free to move on with my car!   So, what does the future hold…. Well I’ve pretty much got to start
  • After a bit of testing with various polishes and pads, we found that the Lake Country wool pads with Scholl Concepts S3+ followed by S20 Black on a meguairs polishing pad, then finished with S30+ on a
  • Over the last few months, a friend of mine and I have been undertaking the most thorough detailing work I’ve ever undertaken. Just over 70 hours of work have gone into my car, from 2500 and 3000g
Well I was hoping to give a little update saying that I’ve added a set of camshafts to the spec of my engine so I’m able to take full advantage of my CNC ported head, CNC ported lower Plenum and SuperTech valvetrain......
However, no amount of Man Maths I do can generate another £1500 to go into this build. So for the mean time, I’m having the heads machined for extra lobe clearance, so whenever I can afford to update my cams, they can drop in without the need to remove the heads again for further machining
A little gutted, but hey, cant always have everything our way!
Edited by nickz32
What cams were you hoping to use?
EPR Genesis 1 cams.... 272degree @ 10.2mm lift
Why do EPR want your core camshafts?
They do?
Edited by nickz32
I was going to guess they were regrinds, but that doesn’t make sense as regrinds usually have a reduced base circle, which the EPR one don’t (they retain the OE base circle)
Quite possible, and they’re then “fully hardened” with some form of hardening process?
As and when I do change cams, it’ll coincide with changing to adjustable exhaust pulleys, larger TB’s and extrude honing the OE upper Plenum.... but that’s probably some way off. There’s some chassis based “madifications” that are further up my “to do” list
Edited by nickz32
Spelling....ish
Hahahaha..... should have put my glasses back on before typing that :lol:
You can reprofile a cam by removing material from the existing lobs but it can increase the stress levels and make
it more difficult for the followers to keep in contact with the profile especially at high revs. Starting with a blank or
building up the lobs can give a new profile with lower stress and easier to follow at high revs.
A local company to me that build engines, also specialise in porting and head work. I had a camshaft from an Uno Turbo(!) reprofiled by them about 20 years ago and the owner showed me the process. He was very knowledgeable and gave me a little tour of the operation. At the time he used to do all the camshaft profiling and head work for Piper Cams which was quite lucrative and when I ordered a Piper cam and given a local address for the core, I thought I’d check it out.
Seemingly the company is still going, I wonder if using a local company to do the work to your specification in the future would work out more cost effective?
It’s can certainly be a consideration...... although Piper cams were never regarded as top quality products
I thought that was just the norm, grinding the stock cam without adding meat and then just adjusting the clearances to suit is the bargain basement way!
Which is precisely what JWT do, just starting with fresh cores
A little EPR update. Main caps have been bored and honed. Now it’s time for the cylinders to get the same treatment
