A couple of HICAS advisories on the MOT this year that i want to prepare for in plenty of time for next year, so what are my options and does anyone have the things i need in good condition?
Nearside Rear Track rod end ball joint has slight play (2.2.B.1f)
Offside Rear Track rod end ball joint has slight play (2.2.B.1f)
Are these specifics still available as new, or as pattern parts? Or am i looking at decent used versions?
i have a lockout bracket to replace the rack, but not the bars that replace the track rods i think, so of no benefit in this instance.
Double check which ones they are. Both outers and inners are still available. Genuine outers are not too expensive, inners are a little more so. I would NEVER recommend such things as bearings, joints and bushings second hand.
If it's the outers that need doing, I'd recommend getting a couple of spare lower brackets and refurbishing them with NISMO bushes and new HICAS joints.
Genuine outer joints - http://www.allcarpartsfast.co.uk/search.php?search_query=5515430P00&x=47&y=6 @ £47.98ea
Genuine inner joints - http://www.allcarpartsfast.co.uk/search.php?search_query=4852135A06&x=47&y=11 @ £73.21ea
The inner joints are part of the link arm.
Ebay outer joints - http://www.ebay.co.uk/itm/skyline-r33-r34-gtst-gtr-gtt-hicas-ball-joint-rear-wheel-steer-/222528996637?epid=1888718355&hash=item33cfc3051d:m:maGO4ybg6NdwblZ3BkF3l-A
Ebay inner joints - http://www.ebay.co.uk/itm/New-HICAS-Rear-Inner-Tie-Rod-Conceptua-Fit-R33-GTS-T-Skyline-RB25DET-/131681018951?epid=2135671632&hash=item1ea8cce447:m:mYATZ-R3FZzRxuCowBUAJtA
More and more parts are available as pattern parts now as the cars get older and Nissan`s commitment to keep up parts supply gets less, mostly all steering and suspension parts can be sourced as pattern parts, from experience the quality is good too.
Jeff
