I'm going to do the coolant bypass, the green lines is where I need to install the bypass pipe. The YouTube video (
) which shows how to do the NA coolant bypass doesn't mention the pipes I've circled red. So I guess these have to remain. Unfortunately I've cut one of them. I'm guess if I simply remove these; coolant will be pumped out everywhere?
Also, one of the main reasons I've removed the plenum was to replace the knock sensor. I understood I could get at it by just removing the plenum, as long as the EGR was removed, which it is. However, I see no way of getting to the knock sensor without removing the lower intake manifold, which I wanted to avoid as I don't want to mess with the timing belt (plus the extra work/time removing the intake). Any suggestions?
Ok, I have my plenum off finally!
Cheers!
