300zx tt hard to start when cold
I'm still having problems getting the 300zx to start when cold.
The car will start when warm and also will start once it's been running for 30 seconds or so.
At the moment when the cars cold I have to let the engine crank over and hold the accelerator down and when it try's to start ease the accelerator to get it to idle.
The car has no error codes
No air leaks
Compression readings stone cold are 164 165 164 and 153 150 153 taken today.
It's currently mapped on a nistune board but prior to that map it had a John Dixon chip and the cold start issue was still there.
My basic spec is:
Weisco forged pistons
Cometic head gaskets
Gt525 turbo's
Ams manifolds
Full 3 inch exhaust system
Z1 ba intercoolers
Z1 2/1/2 inch intercoolers pipe work
Robz 62mm throttle bodies
Nismo 615cc injectors
Walbro fuel pump
Induction kit
The car has had a new engine loom fitted prior to my ownership and the injectors and fuel pump are brand new as I thought these could be the problem. Iv also had it suggested that it could be an earth fault, so I earthed everything using jump leads and it was exactly the same.
Any ideas what to check next? Anyone else having similar problems?
Don't use the accelerator until it's stsrted. Just try turning it over and when it starts use a little throttle......
Edited by TonyB
Has the car been mapped from scratch with the Nistune board or did they copy the maps and settings from John's chip/maps ?
You can try starting it with disconnected temp sensor and see if it makes a difference.
Aux. fan will turn on, but ignore that.
Car was mapped from scratch.
Andrew I haven't worked through that from the fsm, so I'll have a look through that lot.
Iv just tried disconnecting the temp sensor and its exactly the same.
If I don't depress the throttle and just turn over with a key it won't start.
Edited by Dbiagioni1
who did the loom swap?. I had similar issues when the earth point from the loom wasn't connected correctly at the back of the block near passenger turbo.
