My Zed is back from Lee....
HI all,
I will post images soon in my journal but thought id update... she is back and although the main reason for sending it to Lee wasn't fixed, super frustrating, the rest of the work is absolutely amazing. Below is a list of what I have had done:
HKSSK401 Spark plugs
Boost gauge and A pod pillar fitted
Oil temp and water temp gauge supplied and fitted into a pillar pod
Powder coated plenum
Powder coated water pipes
Powder coated boost pipes
powder coated air intake pipes
All upper gaskets and Cam cover gaskets x8
Welding OSF floor
Air con delete
EGR Delete
Water bypass with EGR Blanking Kit
Cam belt correction, one tooth out....don't even go there!!!
5 Brake pipes, 3 front to rear and 2 at front hubs
oil and filter change (engine)
Rear crank seal replacement
6.5 ltrs ATF for trans
Both front ARBs
Both upper control arms
Bleed entire braking system
x3 solenoid deletes
New balance bar seal kit
Installation of 6 coil pack connectors as most were broken
2 injectors
3 air control plugs
1 Replacement coil pack
5 ltr anti freeze and flush
Oil sender replacement
Headlight wiring fault
Remount oil cooler into a better position
Various silicon hoses
temp sensor replacement
Steering rack and wheel tightened
Series two pod replacement for temp
Heating actuator solenoid replaced
Cross member painted
Cats hollowed out
Photos soon...I promise. The car is so different...even in the torrential rain on the way home.
LOL, yeah but all the leaks are gone, the control and suspension parts make it handle well and the power delivery is far, far better....I'm not just after the looks You know!!!! :innocent:
Heater still blows cold air....will be looking into it when I drop it back for MOT....Blocked matrix, sometimes it worked, but now it doesn't.
...apart from that though its different car, all kudos to Lee, he knows his stuff and I couldn't be happier with what he has done.
That's a long list..he's a top man is lee:) can't wait to see him soon and collect my zed,not having anything else done to it after this,I'm stopping spending on it...:whistling:
Hahahahahahahahahahahahahahahahahahahahahahahahahaha....................yeah right !!!!!!!!!!!!!
Funny, last I heard you might need some new snails along the line :whistling:
LOL. Respray?
Did I say something out of term then? Ok ok just a respray then that's it :)
Considering you had two failed injectors I'm not bloody surprised! Bet it drove like a diesel panda car before all that was fixed.
To be honest it seemed loose but not too bad, I had driven worse....previous owner and his mechanic must have been horrendous. It drives so well, doesn't leak and has more power than before. Sounds glorious now. So, so pleased. Just a little cold in there now.....
