Do any of you guys rebuild power steering pumps?
Got a leak so need to get another ps pump.
I see you get rebuild kits but that's the kind of job I hate.
Does anyone in the club do this kind of thing?
My plan is getting a second hand pump, get it rebuilt then it's just a case of getting it fitted.
Thinking of doing a recon on the alternator as well as it also has to be removed the change the pump I believe.
Thanks,
Daz.
I've changed the power steering pump & did not need to remove the alternator?
As Joel said, I also had to change my high pressure hose after!
Front of the shaft has a seal IIRC that can leak. Mine was pouring out of the resivoir line, no longer a Nissan produced item.
Pretty much all the hopses have been changed, some twice.
With the pump being 25 years old I think it's best just to get it rebuilt, no matter the condition after 25 years it will not be perfect, any more hose issues could be dealt with at the same time.
I read another few posts where It said taking off the alternator helped with access, you guys know better though :)
I have rebuilt two now successfully.
Fancy rebuilding another? :)
possibly. I have one here to build back up. I have just got to find the kit!
I take it the one I rebuilt and gave you didn't work then if you've rebuilt two. :oops:
My z has a rebuilt na one I did on it. the tt one you gave me is on the track z I have a third one which was the shorty
Only place that has all the seals from what I can see is CZP.
They also have the drive shaft as well I think.
