October 29, 20169 yr Hello all... Sad news this morning that I need help with - car started on first turn of key but immediately died. On turning key again it turns over without any problem, but doesn't start. This morning I was testing a passive tweeter crossover and last weekend installed the new carpet but it started up last weekend no problem . Where do I go :s it's just sat here for a week and nothing else has changed. No intermittent issues in hebpasy year Fuel pump primes as usual on the first turn of he key you can hear it fire up. Guess I will try and get codes and see if it shows anything
October 29, 20169 yr Author Doesn't appear to be going into diagnostic mode - doesn't show any red led?! Could it be a factory immobiliser?
October 29, 20169 yr Author Aha okay it was flooded Got it started after draining the system but major misfire on passenger bank
October 29, 20169 yr Aha okay it was flooded Got it started after draining the system but major misfire on passenger bank I'm going to take a guess it's spark. Check the passenger side coil packs and see if they make a strong spark.
October 29, 20169 yr Author Annnnd misfire seems to have gone... soiled plug from failed start perhaps? Stupid car gave me a proper scare Edited October 29, 20169 yr by wchestnutt
October 29, 20169 yr Annnnd misfire seems to have gone... soiled plug from failed start perhaps? Can I have a zed like yours... Self fixing optional extra! Lol
October 29, 20169 yr The plug will have been fuel fouled Bill, once the heat got to it, it burnt off. Interesting that it did it though, time to check a few things. The ECU temp sensor and connection would be a good start and pull your ECU codes.
October 29, 20169 yr The led will illuminate if the ECU has power. It does have to be in diagnostic mode to show the codes though.
Hello all...
