- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Ok, you may remember I painted my Zed in a gazebo using cellulose about a year ago, despite all the warnings (yeah ok, maybe I should have used 2K...) -
http://www.300zx.co.uk/forums/showthread.php?182675-Base-coat-no-need-for-cutting-compound
I screwed up the first time by not mixing the paint properly, but this year I did a refresher coat (after properly mixing the paint) and then several clear coats. Using G3 and a polisher my results were very pleasing (a little orange peel on the bonnet but acceptable) and I was happy, all the hard work, time and money was worth it -
Then after a few months when finally summer came this happened -
After some research my theory was that I'd applied the clear coats to quickly, and perhaps too thickly when it was too cold for the solvent to evaporate fully. So, it got warmer, sun hits the paint and the remaining solvent wants out, then the clear coat cracks... However, it's almost like the clear coat is shrinking and causing itself to split and crack. The second time I painted I made sure I gave amble drying time and applied thinner coats, but sadly no difference.
I've been battling the reaction for months now at weekends, rubbing down the clear coat back to base, repainting...however today I noticed my re-painted tailgate of about 3 weeks ago has started reacting again. It's truly sole destroying, and the finish I'm getting isn't as good as I had first time around.
The reaction only seems to happen to the clear coat, and then this affects the base a little, but rubbing off the clear coat (which takes some doing!) gets rid of the worse part of the reaction. Catching it early seems to be the key, before it has time to affect the base.
My Zed currently looks like this (bumper fitted today, and will likely react once the sun hits it) -
The front wings are not clear coated - and so far have not had any reaction. The doors and bonnet are covered in several thick coats of high build primer ready for rubbing down....
The problem is, it's been 4 years rebuilding my Zed, and this is destroying my motivation.
The big problem is my Zed isn't on my drive, and I need to move her in a couple months time, so time is running out. I have nowhere else to paint, so once I lose the drive that's it.
My options -
1 - Strip back to bare metal. (Not really realistic given the timescales, plus I don't think I have it in me anymore. :( )
2 - Don't use clear coat, even though it protects the paint and looks nice and glossy.
3 - Apply bar coat. I'm really considering this, seems like the logical option, but haven't spent enough time researching it, but it seems expensive - £30 for 1 ltr.
4 - Stick my Zed on ebay as a failed project. Not something I want to do, given that it's been 4 years of my life. I spent a lot on parts etc and I'm not a quitter, but sometimes maybe you just have to cut your losses. :(
Thing is, bar coat is to stop the reaction from previous paint...so theoretically it shouldn't make any difference as I don't think that's the problem. I've been buying all the paint supplies from the same place, so surely it should all be compatible. Stripping back to bare metal also won't solve the problem, if it's something to do with the clear coat. I think I may contact the supplier I've been using, just to check it is compatible.
Any advice would be greatly appreciated, as I'm at a bit of a loss. Time (and my motivation) is running out.
Edited by MasterCookieman
