Auto box?
Having returned off holiday I got to grips with changing the power steering hose!
Also replaced my 4 induction pipes.
Now I place box into drive & it will not engage!
Place into 2 it engages then if I move lever into Drive it engages normal!
Auto diagnostic shows No 3 fault.
Can changing the induction pipes cause this problem?
No rattles or mechanical noises from the gear box & no issues before.
I have checked the connections.
Thanks Stephen,
I do seem to have upset the idle speed which is high.
I have driven down to Lydd today in the Z.
So when the z is moving from 2nd then into drive gears change fine.
But if I stop I have to drop the lever down into 2nd.
I will check the TPS but cant remember moving or knocking it!
How do I clear codes? Disconnect the battery?
Checked all connectors.
TPS definitely not moved.
Battery disconnected over night.
Same problem have to put into 2nd for auto to engage & drive.
I can then place into drive & gearbox changes up!
Revs are still high too! At 1400 rpm in N & D with no uptake of engage when stopped!
What's next
By the way the z drives great only for this!
Odd that your Idle speed is up too. It's all kinds suggesting that your TPS is A factor. Have you tested and set TPS voltage?
