Help me with my parts list...
So, I'm swapping all the external components from one engine to another and am making a list of all the gaskets etc I need, feel free to add anything I've forgotten.
2 x exhaust manifold gaskets
2 x manifold - turbo gaskets
Oil and coolant O-rings 12?
Rear sump rubber seal
Front sump oil seal
2x head to lower plenum gasket
Upper plenum gasket
Oil tree gasket
Fuel hose clips - any suggestions as the ones I have are complete crap and easily split. Do you use a normal style clip or jubilee clip?
Any suggestions for replacing the o-ring style rubber bits on the front of the timing belt covers, new ones are a bit pricey?
Cheers guys
Yes, both front and both back will be swapped. I thought they were just RTV silicon sealed though?
Yes, but i was thinking about thermostat O rings, and also my rubber hoses had corroded onto the aluminium. Just a thought.
Does the thermostat have an o-ring? Mine didn't come with one.
All my hoses are silicon and came off fine, they'd only recently been put on there but found the seal around the rear of the crank was badly scratched on the engine I purchased and leaked oil badly so it's just come out again for the new engine!
Edited by Eggs
Perhaps not then, I thought I remembered taking one off.
The silicone hoses should be fine to reuse also.
get these fuel hose clamps: https://conceptzperformance.com/nissan-oem-300zx-fuel-hose-spring-clamp-z32-16439-16e0a_p_5657.php
These were used on the later model Zeds and are lots better then the older screw type clamps
If your going to change the filter tree, change the 0 ring inside it too.
Good thinking that man, pretty sure I did last time but I'll do it again anyway.
Thanks Lymon, are these strong enough for use with a setup running higher than standard boost?
these clamps are for fuel lines.. amount of boost is not relevant for fuel lines
OK thanks. I thought the fuel pressure increased with boost hence the vac line
Can anyone tell me the ID, OD and thickness of the timing belt washers and how many are needed?
Cheers Andrew, can't get your link to open but I'd read 15 on a couple of other sites so wanted a second opinion :thumbup:
