Coolant hose prob
Hi I hope someone can help me, where the rad hoses meet the aluminium pipe at the top engine on the other end of the ali pipe is two small hoses, the right one has a small leek, where can I get them or maybe a complete set ? Any ideas. Steve
I just bought some silicon hose and cut it to length.
The inner diameter is 30mm btw
Edited by Alic
As Jeff liked it, I'm sure it will do the job.
I bought it from autosiliconehoses (they have an amazon store). I bought a length of 250mm so that i had enough pipe for 3 sections and then some in case i messed it up. it was about £5
I haven't tested yet but i hope that the clamps on them will put enough force for a seal with the silicone
(link for black hose: )
https://www.amazon.co.uk/Black-Length-Straight-Silicone-Coupling/dp/B00UI59WMY/ref=sr_1_1?ie=UTF8&qid=1461528060&sr=8-1&keywords=30mm+ID+Black+250mm
Edited by Alic
Do as Ali suggests. Use the spring clips provided stock, hose clamps like Jubelies are a nightmare in that position.
If your clips snap when getting them off (as mine did) I have some extra i can send to you.
Edited by Alic
