- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
So some of you may recall me showing how i was going to utilise the LHD oil pressure sender hole to mount the oil temp sender. I even messed about and checked that it all fitted on the bench with a spare I oil tree had. That went smoothly. Today I grabbed a spare hour and attempted to fit the sender. This happened;
Initially I thought, shit, damn, **** and further expletives. I know how much of a nightmare removing the tree is. So in my thought train I looked at the tree. It seems this block has a funny little bracket in the way, it's a hook type thing, right in the bloody way of one of the bolts. So that is a no go. After I calmed down I realised, actually how much of an issue is this. Effectively I've just fitted another bung, just one that cannot be removed. Obviously it was tight or it wouldn't of sheared, I also used a dab of RTV. So a seal should of been made.
So other than disabling the hole, it's unlikely to of caused an issue. Just a case of fire it up and see if it's sealed, which logically it should be right? Bloody thing won't start now though, probably because it's 2ft off the ground at the front and it was nearly empty of fuel. Hopefully that's just a simple problem.
Oh stuff like this is annoying isn't it.
