How much wire.
What length wire should suffice for head unit and 5x speakers? Is 12 gauge overkill as I'm using that for the Base anyway?
Sent from my VG30DETT
When I installed the 5 channel amp in the boot (on the right side near ABS unit) I needed 6 metres for the +12v
supply from battery for the amp power supply and 1 metre for the amp eartling. 5 metres for each audio channel
from headunit to amp (they come prepared in 5m lengths with RCA plugs). I used about 10m for wiring the door
speakers and rear speakers and about 2 meters for the subwoofer (left side of boot).
Avoid CCA (copper coated aluminum) cables for the power supplies.
Edited by AndrewG
Thanks. I'll be ordering oxygen free. 50m should suffice.
