Last winter I did a major overhaul of my suspension. Two of things I fitted to the rear were adjustable traction rods and I deleted the hicas. The kit I used effectively converts you to NA style rear arms. The issue I have, is the passenger traction rod has a habit of changing, pot holes etc cause it to change. I did consider locktiting it, however I've started to wonder, do I actually need this extra complication.
The ball joint on the lower arm is a fixed position. So toe adjustment is changed by front AND rear arms. This is just over kill, no? A fixed length traction arm should in theory make life simpler.
So should I, replace with fixed length stock ones or just lock tite the adjustable ones because there is benefit.
