99 Spec Replica Headlight insert and the Halo question
Does any know what is the size of the Halo / Angel Eyes required for the 99 Spec replica headlight insert? Any recommendations where I can get one? I would prefer LED type but may consider a Solid ring in white.
I know the HALO/Angel eyes look good with the normal headlight inserts, how does it look with the 99-Spec headlight insert?
The first part on an 89 insert looks retrofit and something i will not fit again, fitting at the back of the dipped opening on the 99 is as factory look as you're gonna get.
Suggest you check out some of my threads :thumbup1:.
Does it look retrofit if you use a Halo? How does the 99 Spec inserts look in chrome? Anyone with any examples.
