- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
i'm looking to try and shed some light on my front vac lines working off the attached pic, the pipe with 3 red dots should be the recirc valve and the forward 2 pipes together should be the carbon canister, now these were connected to the correct ports on my engine but when i pulled the recirc line to replace the hose i had already disconnected it at the valve, so i blew through it to check and i couldn't even blow through it as though something was connected on the end.
i then pulled what should be carbon canister line and connected some hose to it and blew through it and this was connected to the recirc valve all in all very strange all the pipes looked original at the recirc valves anyone else come across this? or is the info on this pic wrong?
