Brake set up
here we have a bigger brake setup which i had on my Z and i found it to be much better stopping than standard, the front is a floating rotor type 330mm disc (standard is 280mm) comes with the calipers off my import Z with goodridge stainless brake lines attached and the brackets with all the spacers nuts and bolts ect needed to direct fit.
the rears are standard size discs again with the calipers off my import Z with goodridge stainless brake lines attached.
all calipers come with pads which have plenty of life left in them as well as 20mm hubcenrtic spacers included if needed for the fronts because of the disc size, all for £250 delivered.
What make are these pal? Might be interested, are they all true without any warping?!
Sent from my LG-D855 using Tapatalk
seemed fine to me and cant honestly remember.
dan.
Hi mate, very interested in this, can i have 1st dibs pls, give me a chance to get home & check my finances?
James
Second dibs please dan if JJP doesn't want them :)
dan.
Check your PM Dan. Cheers
ok will be in contact if jimbob442 changes his mind.
would the fronts fit inside the OEM alloys? Or would I need bigger wheels?
i was running these with 18s and needed the spacers because of the offset not sure about oem but remember the front discs are 330 wide with caliper on end might be tight, but got my old wheels coming up for sale soon so! :whistling:
That's very good value! I sold my stock callipers with worn disks for £170!
Hi Dan, do i take it theyre provisionally sold to jimbob as i did send u a PM last night asking for payment details?
James
  • 3 weeks later...
:cursing::oops::confused1::cry:
Still pissed i missed out on this.....
Anyone else with a decent brake set up pls for sale pls pm me....
