Evo Brembos
Right, I've just been offered a cheap set of freshly powdercoated Evo Brembo front and rear calipers, the problem is they were totally stripped down for powdercoating and now have no internals, pistons etc. Are they hard to replace?? are they expensive to replace?? Is it worth my while??
Richie
  • Replies 32
  • Views 3.5k
I've GTR's on the front already, that's why I was asking if it's worth swappig them out for a full Evo setup front and rear. Are the Evo rears a straight swap? The €1000 wouldn't include pads or discs, it would be just to replace all the missing components from the calipers. I would then have to buy 350mm Evo 10 discs and a mounting bracket.
My thoughts were sell the GTR fronts including discs and this might cover 50-60% of doing the Evo setup??
What do you think?
My Brembos are from an R34 GTR. They're bolt-on ie you don't need any brackets or any modifications for them to fit.
Where do you get your Brembo parts ?? from Brembo direct or retailer?
Sorry for all the questions but as funds are now running low, I've to be careful in deciding "what I need" over "what I want".
conceptzperformance hooked me up with everything to do a complete overhaul of my brembos
dan :)
I did get the callipers from a member on the forum I made my brackets and the rest all from Ebay lol
  • 9 months later...
Have you had any luck with the rear Evo Brembo brackets Buddy?? I can't PM you as you're not subbed anymore
