i'm looking at converting the zed to electric cooling fan rather than the viscous unit, i've found a package for around £80, it includes a 38mm top hose adpator with the temp controller in, and a 14" fan (i have the upgraded alloy rad) the kit however only does 2 temp ranges so not sure if either are suitable for the zed it run either at 87 degs on 83 degs off or 92 degs on and 87 degs off would either of the ranges suit the zed?
other issue relates to the seat belt series 1 j-spec type when driving i notice the belt is going loose, it's not on the top mount causing this, if i tug on the belt twice just above where is come out of the door card it pulls tight again, was there a fix for that somewhere?
final issue since lowering the car i've got the tailgate knocking when i hot deeper pot holes, i've checked the latch and that is on maximum adjustment downwards are there any other adjustments to try and tighten it up slightly?
