Just replaced my below ohm spec injectors today and it's still misfiring and idling horribly.
Replaced the sparks, cleaned tps, maf and injector plugs, checked for vacuum leaks etc all seems fine.
Running a power balance test almost stalls the car it only just hangs on in there, the only thing I can spot that's maybe not right is the lhs o2 sensor voltage, it's higher than the right.
Any ideas?
