Powersteering
Can someone tell me where the powersteering hose is please with pictures would be great. Many thanks. It's because I have a leak. Cheers again
Edited by raph1982
Pot, to pump via a roughly 1" diameter pipe. This is a preformed unit, it can be replaced with general hose with a 90 elbow that's how mine is, parts hyphose. Then a high pressure feed line that runs down from the pump to the rack, these rust at the bottom and leak. Mine was reconditioned by thread and pipe. Then there's a low pressure line from the rack to the pot via a hard tree, again replaced with hose from hyphose.
The pump itself has two top mounted I rings that can fail, and a pair of body gaskets. With the NA there's only one circuit and access us easier. Clean it off with WD then pop a piece of board etc under the bay and turn the engine on. Then trace the leaks origin.
